start stop loop
You can hide a control by setting its visible property to false.
Ben64
Message 11 of 22
(2,671 Views)
thanks, but I was wondering if it was some better method
Message 12 of 22
(2,669 Views)
Have a look at the Master/Slave and Producer/Consumer architectures from new - VI from Template and from the LabVIEW examples. It might look more complicated at first but it can save you a lot of time later.
Ben64
Message 13 of 22
(2,660 Views)
Instead of an extra boolean and local variable, you could create a local variable of the gauge and do the comparison in the second loop. Keep it lightweight!
Message 14 of 22
(2,658 Views)
Accepted by topic author gringo63
send it as a bool notifier, no switch involved...
Message 15 of 22
(2,648 Views)
Tanks, this is intersting.
At first glance, seems to work, but in fact a strange thing happens, the two LEDs lambegguano with the same frequency, whereas I would like them each with their own. The problem is caused by waiting for the notification from the second cycle. I think I will use the smallest delay in the main loop ( none in the second) and using some math with remainders I can arrange the leds blinking rates. Pheraps it would be better to use queque instead notification.
Message 16 of 22
(2,629 Views)
at first glance, seems to work, but in fact a strange thing happens, the two LEDs blinks with the same frequency, whereas I would like them each with their own. The problem is caused by waiting for the notification from the second cycle. I think I will use the smallest delay in the main loop and then I causing the remains as I'm arranging the flashes
Message 17 of 22
(2,626 Views)
Wire a 200 constant to your wait on notification
Message 18 of 22
(2,620 Views)
So why did you mark it as solution? Seems way overengineered for such a simple task and, as you noticed, it is constipated. 😄
Message 19 of 22
(2,619 Views)
Also notice that you can use a single loop running at the greatest common divisor of the different blink rates. Now you don't even need to communicate between different loops. 😄
Here's a quick draft. Modify as needed.
Message 20 of 22
(2,602 Views)
