start event structure with local variable
Hi all...
I have many Event structures which runs by user pressing buttons. Now i want to automate these buttons in certain order. I have tryid to automate these buttons with local variables. In this way buttons are pressed, but Event does not run. How i can do this easily?
thx again 🙂
(4,679 Views)
You should use "Property node" -> Value(Signaling) to activate the event structure.
It doesn't works with local variables or just "Value" at "Property node"
Michael.
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(4,676 Views)
You can also create some dynamic events and launch them where ever applicable..
Guru
CLA
Regards
Guru (CLA)
(4,659 Views)
... or, you could rewrite what you have into a Queued State Machine and get rid of those pesky little Local Variables and Value (Signaling) Property Nodes.
Message Edited by jcarmody on 11-16-2009 05:10 AM
Jim
(4,655 Views)
Mishklyar,
Your user icon shows up as just a red X.  The image file is not accessible.  Instead of hosting it on a 3rd party website, either add it to your image gallery or post it in the Icons Thread as an attachment.  Then have your user icon point to that file location.
(4,606 Views)
now i am a Cowboy 🙂
(4,591 Views)
property node - Value (Signalling) is the appropriate one for the query.  Signalling is just equivalent to user manipulating the front panel and henct the event is triggered while using Value (signalling) property node.
Post back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(4,582 Views)
