stand alone application with VISA
 I build a stand alone installer application from my VI using LV 7.1 VI which contains some VISA serial communications with a standard RS232 port.  In build application wizard settings I checked the Serial Port Suport in Advanced settings in Installer .When I installed this stand-alone app on a new PC without LV installed the communication didn´t work: Error -1073807298 - Could not perform operation because of I/O error.
I don't know if I have to install something else on the target machine. I have seen some topics in discussion forum about the VISA run machine. I imagined it would be included in the installation I had created. If someone could help me I would thank.
Celia
Message 1 of 13
(3,982 Views)
hi Claudia,
I can't say to you what you should exactly because my current labview version it's 8.5. But I use many times RS232 and it's necessary to install visa runtime. You can download it in NI website
Software developer
www.mcm-electronics.com
PORTUGAL
Message 2 of 13
(3,978 Views)
If you are using VISA functions in your application, you will need to install VISA-Runtime Engine on target PC.  Make sure to install version of VISA-Runtime that matches version of VISA installed on development machine.
Message 3 of 13
(3,974 Views)
Hello Celia, I have written LV7.1 application with serial port support and I can state that checking Serial Port Support for the installation package is perfectly OK, so the error must come from something else.
Do you have a built-in serial port or an external adapter?
Paolo
Message 4 of 13
(3,970 Views)
Hi guys,
The first two answers tell me to install the run time VISA machine and the last one said that what I did is OK. I´ll try to install, because I don´t know what to do. I´ve tested the communication using the Hyperterminal and it is working well. So it exclude hardware problems.
Thank you.
Message 5 of 13
(3,950 Views)
I suggest you use MAX on the target machine and verify that VISA-Runtime is installed.  It may have been included with your initial installer.  I have not run that version of application builder.
Message 6 of 13
(3,944 Views)
I ´ve just saw at http://digital.ni.com/public.nsf/allkb/D26B50B17AA9C3FD86256F1F00661A49 that I don´t have to install the  VISA Run-time engine. So, does someone has any ideas?
Message 7 of 13
(3,937 Views)
Hi Celia,
You might check to make sure that the VISA Resource Name you are providing in your application is the same as the name the new machine is using.  If you build the application and it is looking for a specific resource that does not exist on the new machine, you might see an error similar to this one.
Donovan
Message 8 of 13
(3,910 Views)
I don't see that statement in that link at all.  It says if you don't have VISA runtime engine installed on the other machine, you will have to include it in your application's installer.  All of this was in paragraph #1.
Message 9 of 13
(3,895 Views)
Hi Ravens Fan,
I´ve already installed the run-time VISA engine, but my serial communication isn´t still working.
Thank you
Message 10 of 13
(3,866 Views)
