stage freezes multimeter readings
I cannot run in the same loop the code from a motorised stage (Standa 8MVT100-25-1)and a keithley 2000 multimeter measuring voltage. The loop stops after the 3rd measurement of the Keithley when the stage enters into the speed case. See my code attached. I would appreciate some help.
Thank you.
(2,412 Views)
Hi torce,
as you used an event structure the VI will wait for the next event after the "speed" case is finished...
What do you expect here?
(2,404 Views)
Accepted by topic author ka_torce
I do not expect for nothing, in fact I found a solution. If I make timeout 200 ms for example, it will not wait for an event and keep the loop running.
Thanks for your help anyway.
Regards.
(2,393 Views)
