stabilization of measurement
Hello all,
I am trained to measure the temperature of a thermocouple with a labview program but the measurement result is not stable (see graph attached). If you know a way to get a stable value please help me. The labview program is avaible as an attachment (appointed Thermocouple).
Best regards
Message 1 of 13
(1,857 Views)
It would be nice to have some idea of the time and amplitude scaling.  Are we looking at "noise", a "bad instrument", or what?  The measurement seems stable enough, just has a lot of variation.  Maybe the physical situation you are measuring has the same variation ...  Or maybe the code you are using is inserting "random noise" into the data.
Message 2 of 13
(1,819 Views)
Bob Schor, thank you for your reply.
The time scaling is: 0 to 500s
amplitude scaling is: 0 to 100°C
The thermocouple works well because i tested it with a multimeter. I believe it is noise that destabilizes the signal and i don't know how to solve this destabilization problem.
Thank you in advance
Message 3 of 13
(1,792 Views)
Over 8-plus minutes, I would start thinking that this is real data, and the issue lies with keeping the temperature stable.
Bill
CLD
(Mid-Level minion.)
Message 4 of 13
(1,788 Views)
From the look of your Vi you are taking data as fast as possible.
What is your hardware?
Does it have proper cold junction compensation?
Also I took a quick look and your data it's hard to tell but it looks like it is within the standard accuracy of a thermocouple, as most common types are +/- 2 degrees C.
=== Engineer Ambiguously ===
Message 5 of 13
(1,780 Views)
billko,
Yes the problem is with the temperature stability. Is it possible to have a stable value with a labview program ?
Message 6 of 13
(1,778 Views)
RTSLVU,
This is the type k thermocouple.
I am using the NI-DAQ 6001 available as an attachment.
Message 7 of 13
(1,777 Views)
Well there's your problem, no cold junction compensation and a low resolution DAQ.
Best you can do is some type of smoothing like a "running average" of your readings.
Message 8 of 13
(1,766 Views)
In addition to what RTSLVU stated-
It appears that you are not using K-Type T/C wire- this will cause measurement errors.
-AK2DM
Message 9 of 13
(1,747 Views)
-AK2DM
I said that too but when I looked for a table to post I noticed the IEC color code is Green with Green/White wire for K type
Message 10 of 13
(1,738 Views)
