sr830 Fast transfer mode hangs up
Dear colleagues. I am preparing a software for noise measurement in Labview. I encounter this problem:
When I switch the instrument into FAST transfer mode for windows (the Instrument becomes a talker and host computer is a listerner), the instrument starts sending data over GPIB.
The short description of FAST mode is here SR830 FAST mode, and the data transfer is described in SR830 manual between pages 97-103.
However, at high data rates (>128Hz) it hangs up even after few hundreds of samples taken, the number of samples vary.
I get the timeout error from VISA read. The VISA read function is set to synchronous reading. Without this setting, I cannot achieve higher data rate than 128Hz.
The cable between PC and Instrument is roughly 2 meters long, so I think this does not cause problem.
(3,496 Views)
Hi Ivan,
Thank you for posting in the forums! I would recommend posting in the Instrument Control forum (found here: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/bd-p/140) for better visibility, since this seems more like an instrument control issue than a LabVIEW specific issue.
Tina K.
Applications Engineering
ni.com/support
(3,434 Views)
Catatina, thank you. I have just posted it there.
Ivan
(3,403 Views)
