square root symbol in front panel
how to inser a square root symbol in the front panel in the given vi snippet? i want to write V3 instead of sqrt(3). using Labview 8.6.
Message 1 of 26
(7,367 Views)
Here
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 26
(7,351 Views)
Hi pcs,
you could use the Symbol font for those labels...
Message 3 of 26
(7,339 Views)
@Ranjeet_Singh wrote:
Here
I didn't read any of the posts, but your VI doesn't do anything...
Jim
Message 4 of 26
(7,316 Views)
In particular, character 0xD3 of the Symbol font gives you the squareroot symbol. It would look as follows.
Message 5 of 26
(7,305 Views)
Thank you all.. I could insert the sqrt symbol in the GUI.
I also want to initialise one of the strings with the same symbol. So I copied the sqrt symbol and inserted that in place of "sqrt(3)"  . but it switched back to a special character. I selected that special character and selected symbol font from the font menu, then it switched back to sqrt symbol. but as soon as i clicked the mouse outside, it reverted to the old special character(may be the one corresponding to 0xD3 in Application Font).
How to fix this?
Message 6 of 26
(7,255 Views)
Hi pcs,
use Symbol font for the whole string, not just for one character...
Message 7 of 26
(7,228 Views)
But in the symbol font there are no alphabets. So I cant possibly write "Um" . Attaching a vi by Lynn to print out all symbols in the symbol font. enter 'symbol ' in the font text box and run the vi.
Message 8 of 26
(7,222 Views)
Hi pcs,
you can display label and caption next to each other. Use label for Application font and caption for Symbol font:
Message 9 of 26
(7,216 Views)
guess sqrt is 0xD6. (214d).
Message 10 of 26
(7,213 Views)
