sql query doute
hi,
        i am using data base sql server in labview.i want select all data from table except some.using the following query but not working.
SELECT *(EXCEPT Column2) FROM Tablename;
SELECT * [except Column2] FROM Tablename;
select * from Tablename except(Column2);
select * from Tablename EXEC(Column2);
select * from Tablenameexcept(Column2);
select * from TablenameEXEC(Column2);
select * FROM TablenameWHERE FIELD NOT IN ('Column2');
Message 1 of 8
(4,945 Views)
I use something like this
SELECT col1, col3, col4
  FROM Tablename;
UliB
Message 2 of 8
(4,932 Views)
Unfortunately, you can't define your own syntax in SQL. If you want just certain columns from a table you have to list the ones you want. If creating this list is too onerous because the list is large, you have a more fundamental problem: a bad database design.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 8
(4,886 Views)
hi,
      i know this but my column is more than 100.so i form query this type too long that y i am try onther methode.
Message 4 of 8
(4,868 Views)
What you need to be doing is fixing your database design. Having 100+ columns in a table is absurd! Other than you and your software, how many other users access this database?
Mike...
LabVIEW Champion
Message 5 of 8
(4,853 Views)
Sometimes you inherit a non-normalized database and need to take baby-steps in the process of repairing it.  This'll build a query with all columns except one.
Jim
Message 6 of 8
(4,834 Views)
hi,
       my field record is more than 1000.so i will use this methode take more time.that y i am asking any sql query..
Message 7 of 8
(4,791 Views)
So instead of 100 columns like you originally said, you are now saying you have 1000+ columns?
Message 8 of 8
(4,770 Views)
