spst
HI
I want setup a button like SPST in Labview...where the logic is something like A or B else C. Can anyone help?
Huz
(3,346 Views)
Your question doesn't really make sense. A SPST switch is either on or off - there's no in-between state (excluding physical effects like arcing, etc). Further, it cannot have an "else C" state.
I'd normally ask if this is a homework question, but your previous posts don't indicate that it would be, so could it be an issue of no hardware experience?
(3,330 Views)
Hello
Sorry for the confusion. This is not a Home work questions. What I am trying to do is use only ONE boolean button to do following three actions:
Press the button once: State On (~500 msecs)
Press the button again: State Off ( ~500 msecs)
Else: Nothing happens
Right now my code looks like this:
 What I would like to do is just one button to do this logic.
I hope this is little bit more clear.
Huz
(3,323 Views)
If you use a latch button and a while loop you could do this easily with a shift register to remember the previous state, but I don't see any timing in your VI. You could also do it with a switch button by using an event structure (see attached example).
(3,309 Views)
