spreadsheet
Hi all :
please see attach file ,, if you can see that i have array size 37 point , inside3 it there is cluster with two point x ,y ..
what i want to do to spread these point in table such as ,, please see jpg picture
who can I go that ,, i start doing it but i stuck
thanks
(3,292 Views)
See the attached file. I've made a simple change to your code so that it could what you want.
You can only open it if you use labview 8.5
Software developer
www.mcm-electronics.com
PORTUGAL
(3,284 Views)
Hi :
first of all thanks for your quick respond.. i solve the problem with another way ... but now i have another problem ,,,, i want to convert  the data to X,Y Chart ,, i did some thing but i don't know if it right ..
please see attach .. what io want
1-  to convert  the data to X,Y Chart
2- if there is a way to see the data on the chart ,, to verity data
thanks
(3,275 Views)
No problem. We're here to help.
To see the xy graph you just have to connect it directly.
To confirm the points, go to the graph properties and make "cursors" visible. Then create a new one (all of this trought right click) and choose "snap to plot"
Software developer
PORTUGAL
(3,269 Views)
