spreadsheet string to array function - what am I doing wrong?
I'm trying to utilize a hard coded spreadsheet in the VI below and allow the user to select which row of the value to call out. Trouble is that the program is not able to read the value at any given row and would return a value of "0" no matter the rows selected.Spread sheet to array.png
Message 1 of 15
(12,340 Views)
You need to change your format specifier from %d to %f.
However, you are making this way too complicated.
See below.
mcduff
Message 2 of 15
(12,328 Views)
  • You need to specify the comma delimiter.
  • You should use a %f format string.  Otherwise values will be rounded.
  • A 2d array is not necessary.  Wire up a 1D array to the array type input on Spreadsheet String to Array.
aputman
Message 3 of 15
(12,327 Views)
Depends on where the data is coming from.
aputman
Message 4 of 15
(12,324 Views)
1. Set your delimiter to be a comma (,).  The Spreadsheet String To Array defaults to use a tab.
2. You probably want to use %f as your format, which is for a floating point.  Write now you have %d, which is for an integer.  Therefore the scan currently ends at the period.
Message 5 of 15
(12,323 Views)
Not needed in this case since there is a new line in between values, if it was all one line then yes. Parses correctly in LabVIEW 2017 without comma delimiter.
Main Problem %d specifier, not %f (There are other problems as you have noticed.)
cheers,
mcduff
Message 6 of 15
(12,317 Views)
From the OP
Should be able to change that to an array of numbers Smiley Wink
mcduff
Message 7 of 15
(12,314 Views)
@mcduff wrote:
From the OP
mcduff
I understood that statement completely different.  A string is not a "hardcoded spreadsheet".  Smiley Very Happy
aputman
Message 8 of 15
(12,311 Views)
I have strange interpretations of words, sorry.
Hard coded to me meant it was stuck inside the code. (Also previously the OP posted a VI in another thread that had the same/similar VI as the one posted here throughout it. That may be biasing me a bit. They weren't reading from an instrument, file, etc.)
cheers,
mcduff
Message 9 of 15
(12,299 Views)
wow you guys even went through my past questions, that's impressive.
But yes I am trying to in some way hard code the values as so users won't somehow alternate the given values unless purposely doing so.
Message 10 of 15
(12,245 Views)
