spreadsheet output
how can I send my output into a spreadsheet without having to ask for the spreadsheet headings to be written everytime?  In other words, can I create a step to write the headings on the spreadsheet and then be able to continue wrting data in the same table without the need to re-create the step for the headings?
Message 1 of 8
(4,817 Views)
Are you using the Write to Spreadsheet File VI to write the data to a text file?  Or using ActiveX or the Report Generation Toolkit to write to an Excel Spreadsheet?
Message 2 of 8
(4,798 Views)
Or are you using Write to Measurement File?
Or are you using Write to Text File?
Or are you using Write to Binary File?
Or are you using the XML functions (if you're trying to use the Office 2007 Open XML format)?
Message 3 of 8
(4,767 Views)
I would do it like that. Hope it helps. If you post your code it will be easier for us to help you.
Message 4 of 8
(4,752 Views)
I am using the write to spreadsheet command
Message 5 of 8
(4,738 Views)
Then you can just do as the code provided by Dimitrios shows. Write out your header first, then write out your data, using the "append to file?" input.
Note that in the example posted the sequence frame is not necessary. All you need to do is to use the "new file path" output rather than branching the wire. This will guarantee that the header is written before the loop starts.
Message 6 of 8
(4,724 Views)
Very good point smercurio_fc,
Just in case you are not familiar with LabView. I have created an array of 2 Headings using strings.Inside the loop i have generated some 'random numbers' for  your first column and added 5 to the same number for your second column. Then i just have build an array with both numbers. Don't forget to put some delay in your while loop so it allows your proccessor to do other things as well.
Message 7 of 8
(4,683 Views)
Sorry i forgot to attach the code
Message 8 of 8
(4,682 Views)
