spreadsheet file
Hi all
Please see this attach file , its program that saved table data to csv file , as you see if you open this saved file you can see all the table data saved in same column
What I want that each number save in different column
How can I do that ?
(2,748 Views)
When you open the file with something like Notepad, it is saved in rows and columns. If you want Excel to open it, then you should use a comma as a separator and not a tab. Using a .csv extension implies a comma separated value and you are not doing that. There is a delimiter input that you can set. Also, why are you using the %t format string?
(2,741 Views)
transpose and then save it
try this and
(2,737 Views)
