spreadsheet confirmation message
 I use the "write to spreadsheet file.VI" and I don't want to confirme when I overwrite a file. How can I modifie this VI, have you got an other solution?
(2,865 Views)
1. Click on write to spreadsheet file.VI to open the front panel
2. Open the block diagram
3. Locate
Open/Create/Replace File.vi
4. Attach a constant F to the advisory dialog? terminal
5. SAVE write to spreadsheet file.VI AS SOMETHING ELSE.
(2,855 Views)
It's strange, my open/create/replace VI doesn't have the advisory dialog terminal. I only have: prompt, file path, operation and error in!!
(I work with labview 8.2)
(2,843 Views)
ok I have solved my problem. But the "write to spreadsheet file.VI" is different in labview 8.2, it use others subVI. I have checked in labview 8.0 where I can see the the advisory dialog terminal.
Thanks for your answers
(2,837 Views)
