splitting up a string into seperate elements
YES!
Very Nice.
Thank you
JCollado
Message 11 of 16
(1,569 Views)
Not sure why but when I tried reading that text file they way you have it I could not read it. It says invalid Path.
It did work when I did it with build string and then string to path.
See attached snippet.
JCollado
JCollado
Message 12 of 16
(1,564 Views)
JCollado
In your string constant 'getArgs.txt', get rid of the slash
Cory K
Message 13 of 16
(1,553 Views)
Yes Sir that was it!
I did not expect that since when I put the path from the get system directory vi it does not have the slash.
Good Job.
Thank you
JCollado
Message 14 of 16
(1,545 Views)
Good Job.
Thank you
One of the reasons Altenbach changed how you retrieve the file name is because of that slash.
Not all operating systems use a \ as a delimiter between a folder and its contents.
This will cause your VI to break on other OS's if you use your original method.
That is why Altenbach proposed his method.
Cory K
Message 15 of 16
(1,539 Views)
Ok
Go Yanks tonight! 🙂
JCollado
Message 16 of 16
(1,535 Views)
