splitter bar : multi-panels but common background
Hello, I am discovering splitter bars which are great to give a functionnal structure to a front panel.
But I was wondering if it is possible to have a common background image for all the created panes (i.e : the "parent" container).
My goal is to set a kind of wallpaper in the front panel background as use panes to give the controls a sort of hierarchy.
So, as I cannot find a solution : is there a way to set a common background in multiple panel front panel?
(2,487 Views)
As near as I can tell there does not seem to be a way to do this, short of copying the decoration to the other pane of the splitter. I also looked into the scripting methods but nothing jumped out at me. Perhaps NI can chime in on this.
(2,458 Views)
That's also my conclusion. Thank you for your answer.
(2,450 Views)
