split channel data display on a xy graph with their own area
I have n channels data & need to display on a graph
However, I don't want them to dispaly on the same area because they will cover each other and not easy to see the difference. I want to display like one channel on one xy graph. However, there are "n" channels & everytime the number of channel will change. Could you please teach me what should I do?
=Labview 7.0 & 8.0 & 8.5=
(3,051 Views)
If you are displaying data channels vs. time then you could use a Waveform Chart. Right click on the chart and select "stack plots" (as opposed to "overlay plots") for the behavior you desire. In labview "xy graph" has a specific meaning. It implies a display of x,y pairs, such that there may be multiple y values for each x value. I suspect, perhaps erroneously, that this is not what you need.
If you truly need stacked xy plots then you can add offsets to the y values of each channel, add duplicate scales for each channel, or place several xy graphs on the fornt panel and disable or hide the ones you do not need.
(3,051 Views)
