split and group string
@icycool wrote:
..btw can u attach ur example vi.
You did not say what LabVIEW version you are using....
Message 11 of 20
(3,316 Views)
ouh..im using labview 2009
Message 12 of 20
(3,310 Views)
After reading through the post, I created a quick VI based on the image that was previously posted.  Please see attached VI.
Jake G.
Message 13 of 20
(3,282 Views)
i cant open ur vi. as it is version 10 and im version9 =(
Message 14 of 20
(3,265 Views)
I'm sorry, my mistake.  The LabVIEW 2009 version of the VI is below.
Jake G.
Message 15 of 20
(3,255 Views)
thanks for vi. TheTician..one thing i forget..my input is in HEX..and i want the output for each of them to be converted to decimal..how do i make it then?
Message 16 of 20
(3,233 Views)
If the input is a raw binary string, here's one possible solution. You did not really specify the output type, modify accordingly if you want a different output (e.g. format to a decimal string). Questions?
Message 17 of 20
(3,218 Views)
thanks altenbach..i want my output in decimal only..so then i will delete the output in hex
another thing,i try to make four 1D array for each of my element which is 1111,2222,3333 and 4444 but it didnt work..can u help me
Message 18 of 20
(3,205 Views)
Accepted by topic author icycool
Here's one possibility. It's a bit inelegant so try to find a better way. 🙂
Message 19 of 20
(3,199 Views)
no problem..i'll change it according to what i need..thanks altenbach..u've been a great help 😃
Message 20 of 20
(3,192 Views)
