split 2d array to dbl double
Have some data I am trying to get out of a 2d array of dbl to put in to a single indicator dbl, what function/ functions do I use to do this?
Any help appreciated
Regards
Brett Scott
Snr Mining Engineering Technician
Western Australian School of Mines
Curtin University of Technology,
Locked Bag 22, Kalgoorlie Western Australia 6430
Ph: 08 90886159 Fax: 08 9088 6151 Mobile: 0407441251
Web http://research.wasm.curtin.edu.au/
(3,873 Views)
The simplest solution is to wire your array to the "index array" function, and to wire the row and column indexes to get a specific element. But I suppose that your problem is slightly more complicated ?
CC
Chilly Charly    (aka CC)
(3,867 Views)
That is the one I wanted, I wired a index zero to this and I get the time, but how do I get the readings I want from the second row, pressure? changing the index to 1 doesnt change the reading. (still getiing time).
Cheers
Brett
(3,865 Views)
Cheers
Brett
there may be some mistake in your diagram. I suppose you didn't confused raw and columns ? If your data are read in a loop, check that the index in inside the loop. Otherwise, post your vi (or a simplified version), someone will arrange that for you.
(3,862 Views)
Cheers Mate, crystal clear now.
Brett
(3,859 Views)
