split 1D array into elements
In each iteration of a loop, I want to take root-mean-squre of the last 16520 elements of a 1D array (the last 10 seconds of sampled data).
But I'm getting the following error:
I also used "to double" converter, but I'm getting the 2nd error massage:
(7,155 Views)
Use For Loop to Index ur FXP Array and use Convert it to DBL.
X terminal of RMS Function is a Scalar DBL Element.
(7,149 Views)
I'm gonna give it a try.
(7,146 Views)
If u need work  just with some elements in array, use Array Subset function to index and put ur desired lenght.
(7,133 Views)
I think I should forget "RMS PtByPt" and switch back to ordinary "RMS" with a FIFO queue:
(7,120 Views)
Accepted by topic author Cashany
Here u go.
(7,097 Views)
