speedometer
I want to create a speedometer of the car
That the gauge is raised can be used to acceleration, gauge is reduced, the use of brake.
The program gears increases each time the acceleration is required is
needs to be created using the case and while loop.
Frame of the front panel basic, to be the case. Want a help.
(3,157 Views)
Hi rok,
it's quite hard to find the "brake" and "accelerate" button when you use asian fonts to label them...
You have to generate a speed value and just display that speed value by the gauge!
(2,876 Views)
