speed
Which is quicker to bundle an integer into 4 different clusters or use one
case statement?
(2,747 Views)
You may want to elaborate a bit more in your problem description. I am not quite certain as to what you are trying to accomplish. Just as a general rule, clusters are more memory-intensive than scalar values, so if you are choosing between using a case structure to select scalar values, and somehow using a cluster, I would go with the case structure.
If this doesn't answer your question, please respond to this post and be much more specific in your problem description. Thanks for your patience, and have a great weekend.
Sincerely,
Darren Nattinger
(2,747 Views)
