speech comparison
Hello, Im trying to make a VI that compares a speech input from a microphone to wav files in a folder. If the input speech matches any of the wav files in the folder it will output a specific text. I'm trying to implement this using Neural net but im stomped. HELP! Thanks 😄
(3,031 Views)
Can you post the code you came up with and explain what you could do, what you couldn't do, etc...
If you go into Help > Find examples... > Search tab > search for "wav" you'll find "Recored Wav File.vi", maybe this will help you.
As to how to compare / match the WAV files... I'm sorry I will be of no help for that. Just use Shazaam Smiley Very Happy
Epictetus
Antoine Chalons
(3,030 Views)
TiTou,
Is it possible to make a list in labview where all the wav files are stored?
(3,023 Views)
