spectrum
hello everyone,
i have implemented a spectrum function on a time domain signal in MATLAB. i want to implement the same function in Labview. i have tried all spectrum VIs in Labview but they didnot give same output signal.
i donot want to use matlab script in my code. can anyone guide that in labview which VI works same as Spectrum function of Matlab?
Message 1 of 19
(3,147 Views)
Hi sundas,
Do you mind to explain which functions with their parameters you use in Matlab?
Do you mind to provide example data used for the spectrum calculation?
Do you mind to explain the differences in the output data? Are the results "different by orders of magnitude" or just "different in the 6th or 7th decimal digit"?
Do you mind to explain which (LabVIE) functions you tried?
Do you mind to attach a VI with those function, with example data embedded, so we can discuss about your results?
Message 2 of 19
(3,139 Views)
i have tried power spectrum, auto power spectrum, amplitude and phase spectrum.
In matlab, i have applied
x = spectrum(x (1:end));
As result, i got one signal curve.
But when i implement the said Labview spectrum VIs i got FFT type signal response.
Message 3 of 19
(3,124 Views)
Hi sundas,
you missed to attach a VI with example data…(LV2017 preferred)
What is the difference between a "signal curve" and a "FFT type signal response"?
Don't you expect a "FFT type" response when you calculate a spectrum???
Message 4 of 19
(3,117 Views)
Attached is the screenshot of spectrum response in Labview and matlab with same input signal.
please see the attached screenshots and suggest something.
Thanks..
Message 5 of 19
(3,059 Views)
Hi sundas,
you missed to attach a VI with typical data included!
(Again: LV2017 preferred)
Message 6 of 19
(3,052 Views)
you can refer the attached screenshots to compare the results.
If it helps you this will be great.
Thank you
Message 7 of 19
(3,015 Views)
Hi sundas,
I have to ask for the 3rd time:
When will you attach an example VI with example data included so we can analyze what you have programmed?
When will you attach the Matlab source code used to create your image?
Just showing images of some arbitrary plots does NOT HELP at all…
Message 8 of 19
(3,010 Views)
Hi GerdW,
Please find the attach zipped folder.
I hope now this will help you.
I will wait for your reply.
Message 9 of 19
(2,992 Views)
Hi sundas,
Two notes:
  • A "zipped" folder should have the file suffix "ZIP". Why do you use proprietary software instead of simple (free-to-use, built into Windows) ZIP format???
  • Right now I'm using LV2017 so you should downconvert your VI…
Message 10 of 19
(2,984 Views)
