spectral lines of RGB Color sensor
hi
I am trying to do spectral analysis of Intensity-wavelength. What I do to connect my RGB sensor to a myDAQ.
i just need to see the signal (DC-Voltage) output on my PC. The sensor has 20 mV - 1,5 V Output.
This sensor detect color change, so I can save the output to a text file using labview.
then i just want to calculate percentage intensity of light for any one wavelength in the source.
How can I use labview to do this analysis and make a real-time graph of Intensity on the Y axis and wavelength on the X axis ?
Also if someone has a VI which can explain me this it would be highly appreciated.
Thanks in advance for any suggesting.
(4,607 Views)
Hi Bocil,
getting the voltage to your VI is pretty easy using the DAQ Assistant Express VI. Follow the linke below to get a step by step tutorial.
NI-DAQmx Express VI Tutorial
http://zone.ni.com/devzone/cda/tut/p/id/2744
Creating a visualization like the on in your screenshot is more advanced. You can use itensity graph or diagram to acomplish this. It would be a lot easier if you only plotted the voltage value, without the repective color in your graph.
Displaying 4 Dimensional Data in a 2 Dimensional Intensity Plot
https://decibel.ni.com/content/docs/DOC-14867
Have a look at the this example, it comes pretty close to your projec:
Light Intensity Measurement
https://decibel.ni.com/content/docs/DOC-16986
Regards, Topp
(4,579 Views)
