specifying max limit range in array
I have got the desired result. I retained one for loop instead of two. I didnt go for nested loop. I used the boolean function , thought it is simpler. IT works perfectly fine now.
 I have attached my VI for your reference.
Thanks for your help.
Message 11 of 13
(752 Views)
hi,
I used the boolean function and multiplication as you said. IT works perfectly fine now..
Thanks for your kind help.
I have attached VI for your reference
Cheers/
Message 12 of 13
(752 Views)
You can right-click on the For Loop you have left and select 'Remove For Loop'.
Message 13 of 13
(747 Views)
