specify a cycle count
How do I read all four channels at once?
Message 11 of 16
(852 Views)
Start reading here
(For example, you could use "Dev0/Ai0:3")
Message 12 of 16
(840 Views)
Careful, Christian.  Notice that the OP is not using DAQmx.  It is some other driver (ULx?).
I have no experience with this driver set.  But maybe the reading of multiple channels will work the same as DAQmx.
Message 13 of 16
(838 Views)
Ah, OK,
I don't have DAQmx installed on this computer, so I thought the missing icons were DAQmx. Hard to tell from a quick glance. 😉
(I also do very little hardware stuff...). Hopefully whatever he's using works similarly....
Message 14 of 16
(835 Views)
the drivers I'm using are for a MC daq. Not sure if that would work for me, considering it doesn't use the M&A.
Message 15 of 16
(827 Views)
If you are not sure, just try it. No m&a needed.
Message 16 of 16
(826 Views)
