source control MSSCCI Credential
Hi all,
My company is changing domain from domain a to domain b, so I need to change the login information to my source control.  I am connnecting through a MSSCI provider to my source control (TFS) in LabVIEW.  I want to change my login credential, but I dont' know how to do it.  It also seems like labview or TFS is holding on to my old credential and will not get go.  Is my old credential saved in some location through the MSSCCI that I am not awared of?  Thanks!
Yik
(2,859 Views)
I am not familiar with how TFS's MS SCC integration works. It is quite possible there is some registry key being set. One thing you can try is removing an entries in the LabVIEW INI file that have SCC in the name. This should allow you to configure from scratch at least from LabVIEW.
George M
(2,842 Views)
