sound file path
Hi Everyone,
I'm using the sound file path to  play with Play Sounf File.vi.
I have to select the file again everytime I close and open labview.
Any suggestion as to how I can make it permanent?
Thanks.
(3,126 Views)
Accepted by topic author OSMAN
Two things to do
1) In Front panel right click on control and select data operations->make current value default, then save
2) In the block diagram right click and select change to constant, then save
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,121 Views)
Glad to help 😉
(3,097 Views)
