sound amplitude
Hello everyone,
I'm having trouble recording a sound file using LabView. I'm using a 3rd Party sound card (RME HDSPe RayDat) which is a 72ch audio card.
The way windows detects the card is Device 1 =  Ch 1 + 2, Device 2 = Ch3 + 4, etc...
I have just tried to use the "Continous Sound Input.vi" and selected Dev1 to record on channels 1 and 2. If I record using single channel (1ch), my measurement seems correct. However, when i try to record from two channels (2ch), my signal on Ch1 is doubled in amplitude, and there is no signal on Ch2.
Ultimately, I would like to have a single microphone connected to each channel and be able to analyse each channel individually.
Can anyone explain why this may be happening?
David
(3,764 Views)
First try using SOUND RECORD express VI. If thing does not work then look for driver update or try changing the DEVICE derive settings.
Please post ur VI & screen shot of device manager showing channels.
I tried using express VI & it works fine for both the channels. Then simply convert express VI into source code of LABVIEW.
Hope this helps.
(3,759 Views)
Unfortunately, using the express VI still have the same problem where 1ch amplitude is not the same as 2ch amplitude. Attached is a screen capture of the devices available.
(3,753 Views)
Provide the screen shot of recorded audio i.e.preview.
(3,747 Views)
Previews attached.
(3,745 Views)
The images shows too much nosie. can you do one thing. Use function generator to outout two sine waves of  different freq & amplitude and apply it as input to CH-1 & CH-2. Then give me the preview of EXPRESS vi. Can you please post the datasheet of sound card that u are using. It will be more helpful.
(3,732 Views)
This is the spec sheet for the soundcard. http://www.rme-audio.de/en_products_hdspe_raydat.php
The microphone is connected to a sound level calibrator (piston mic )running 94dB at 1kHz which we use as a calibrated signal.
I'll see if i can wire up something but it wont be that easy to do at the moment.
David
(3,724 Views)
