sort timestamp array
In trying to sort an array of timestamps, I'm geting unusual behavior. The date order is correct, but the times are in reverse order within a given date. Is this expected bahvior? I would have thought that the internal representaion of the date is a number of seconds (since the beginning of time). As a sanity check I've also converted the timestamp to a double and sorted on that, which gives the same result
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 1 of 21
(7,624 Views)
Hello littlesphaeroid,
Based on your screen capture, the order appears to be correct - 3PM is earlier than 4PM, 12 AM is earlier than 11 AM.  Do you have a different data set that demonstrates this behavior?
Tom L.
Message 2 of 21
(7,622 Views)
The data seems fine. May be you are confuse becasue of DD-MM-YY positions..
Here only 1 function sort 1D array (as yours) and its working.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 21
(7,601 Views)
Their screenshot shows it as MM/DD/YYYY.
Message 4 of 21
(7,582 Views)
Unused elements says MM-DD-YYYY(I Saw that). As it was told earlier that this is perfecly valid but we normally follow DD-MM-YYYY. Just I uploaded the VI with same format.
--Ranjeet
Message 5 of 21
(7,571 Views)
Why would you go and do that?  It just adds one more complication to the question that doesn't solve the poster's problem.  Assuming that he even has a problem which still has to be confirmed.
Message 6 of 21
(7,558 Views)
It depends on who "we" are.  In the USA, it is common to use MM/DD/YYYY.  If you are a programmer, you probably use YYYY/MM/DD.
Bill
CLD
(Mid-Level minion.)
Message 7 of 21
(7,550 Views)
I'm sorry, I think I stupidly thought that 12 AM came after 11 AM!
_____________
Message 8 of 21
(7,527 Views)
Believe me, it's not stupid... but that's why we have the 24 hour clock.  0030 obviously comes before 1130.  🙂
Bill
CLD
(Mid-Level minion.)
Message 9 of 21
(7,521 Views)
No We here needs to follow DD-MM-YYYY becasuse here we are comfortable with that format only.
--Ranjeet
Message 10 of 21
(7,510 Views)
