solar and MPPT modeling/simulation in LabView
Hello friends, I have been looking to see if its possible to do simulations of solar panel with MPPT algorithm and a load?
Something equivalent to this:    https://www.youtube.com/watch?v=h1E0NcPOYYM but without the grid stuff.
Mine would be just one Solar panel 50W with buck or boost converter, a battery as a load, although I would take a DC-AC inverter model that doesn't connect to the grid.
THanks
(4,719 Views)
Yes you can. There is a simulation toolkit, but I have never had very good luck with it. My impression of it is that although it has been around for a long time it isn't used much and so isn't very mature as a product. Still I haven't used it in a few years so it may be better now.
Even without the toolkit you can do modeling in regular LabVIEW.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,693 Views)
I googled for the toolkit but couldn't really find anything.
Know any good tutorials on how to model in LabView?
(4,668 Views)
Modeling in LV is not different from modeling in any other language. You define the equations which produce a mathematical description of your system. Then you implement the evaluation of those equations in LV.
Some models can be trivially simple. For example: Model the current in a resistor as the applied voltage varies. Equation: Ohm's Law: I = E/R.  LabVIEW Program to implement model:
What part of this is giving you trouble? What have you tried?
Lynn
(4,651 Views)
