software trigger aquire x amount of samples
Hey all
Im looking to make a software trigger b/c my hardware trigger has a single multiplicity, so i turned off the trigger such that data constantly flows out of the DAQmx read as an array. I have made my own trigger by using compare to (value), basically when the compare returns true i want to aquire the next thousand signals into an array, i have no idea how i could set that up, anyone know?
Cheers!
Greg
(2,855 Views)
Post your example VI so we can have a look. LabVIEW developers on this forum are more likely to help if you they get to see some sort of implementation of the issue you are describing.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,851 Views)
Ok here she is thanks!
(2,844 Views)
