software analog VI in LabVIEW 8.0
I have an old PCI-6036E card. In LabVIEW 7 it is possible to trigger an acquisition using the  AI Waveform scan VI, which is capable of performing a "software analog" triggering. Is there something similar in LabVIEW 8.0 ?
(2,965 Views)
I'm sending to you a link with an example of analog trigger through software. Once the files on the link are not for your LabVIEW version I'm attaching here the same VIs for the version 8.0 of LabVIEW.
http://decibel.ni.com/content/docs/DOC-11764
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(2,942 Views)
Accepted by topic author ctm
Hi Luciano,
Thanks for your help. The signal I'm measuring is a short pulse (delta T 10 ms, one pulse only). I think the VI's you've just sent me will solve the problem.
Anibal Marone
(2,932 Views)
