sniffing my sensor
Hi Guys,
Here a code that i'm trying to work out and it doesn't show any error in my side yet it still does not read my velodyne sensor
Any ideas.
(2,410 Views)
You have two Event Loops, a Bad Idea.  Your code is a little mal-formed (can't see it on a normal size screen, can't fit the Front Panel onto a screen, you use Tab Controls, also not a good idea, etc.).
I don't know Velodyne, and haven't closely checked your DAQ code, but here are some questions:
  • Can you manipulate your sensor in MAX?  Can you open it?  Can you read/write to it?  Does it seem to work that way?
  • I recommend you read "Learn 10 Functions in NI-DAQmx ..." (a very good White Paper by NI on DAQmx, search the Web and you'll find it).  Kudos on using a Project -- now leverage it by creating a DAQmx Task for your Velodyne (same steps you used when you tested your Device in MAX) right in the Project (right-click My Computer, choose New DAQmx Task, find your Device, configure it as much as you can.).  Once you have a Task defined, you can do most DAQmx I/O with three functions -- Start Task (do a "Create Constant on the Task In side, click the Drop-down triangle and choose the Task you just created), Read, and Stop Task.
  • You do not need (and should not use) the Sequence structure -- the Error Line should sequence things for you.
  • I didn't see how you were communicating between your loops, but I didn't see Queues ...
P.S. -- LV2015 is an extremely poor name for your Folder ...  LIDAR 2015 would be much better.
(2,377 Views)
