smtp credentials with .net could not be wired in labview
Dear All,
could someone help me why i can not connect wires in attached vi pictures.
I like to write a E-Mail program, however smtp requires authorization.
Best regards
Hepman
Message 1 of 15
(3,922 Views)
When I opened your VI there was no broken wire. Are you sure you have .NET 2.0 installed? System.Net.Mail is in .NET 2.0. If you have .NET 2.0 check to make sure you don't have a labview.exe.config file in the same directory as LabVIEW that is explicitly telling LabVIEW which version of .NET to use.
Message 2 of 15
(3,904 Views)
Dear Smercurio,
I working with labview 7.1
What do you mean with
labview.exe.config file, the LABVIEW.ini? Where could I find  what labview use as .NET.
Is it also possible to deinstall .NET ver.1.0.?
Best Regards
Hepman
Message 3 of 15
(3,897 Views)
For proper support of .NET 2.0 in LabVIEW 7.x you need to install the patch to get it to 7.1.1. You can read more here.
Message 4 of 15
(3,894 Views)
That said, you will still have a broken wire since you cannot create the connection you're trying to make. The reason is that you cannot provide the class "NetworkCredential" to "Credentials" since "Credentials" takes a differenct class. I would suggest looking at the site http://www.systemnetmail.com/ for an explanation of how to use System.Net.Mail.
Message 5 of 15
(3,893 Views)
there is written:
smtp.Credentials = new NetworkCredential("username", "secret");
Is this not the same class?
Is it possible to convert somehow the classes.
The class could be the same as seen in the attached picture, but how to select or to connect?
Message 6 of 15
(3,892 Views)
Hmmm.. you're right, that should work. It looks like the problem is LabVIEW 7. When I opened your VI I opened it in 8.2 and the wire was fine. You could try typecasting using the "To More Specific Class" as shown in the attached modification to your VI.
Note: You will still need the 7.1.1 patch in order to get .NET 2.0 to work properly.
Message 7 of 15
(3,885 Views)
I can not convert to labview 7.1.1, because I have to support several machines where I can not change version.
By testing your vi I get the error 1057,  it is not possible to convert to this class.
Message 8 of 15
(3,883 Views)
smercurio was wrong on that last one (it happens).  I'm working in LV 8.2, but I completed the mail.vi and sent myself an email; no broblems, no errors.  I'll attach the pic.  Smercurio was correct about the 7.1.1 patch though to avoid confusuion: You must patch LV 7.1.1 to LV 7.1.1f2.  (His link was correct for the patch).  If you have done that and still can't get a solid wire, the problem might be with the .net installation.  Make sure you don't have any of the .net 2.0 beta installs and that .net 2.0 framework is working OK.  You might give the .net classes a wirl using something outside LabVIEW like Visual Web Developer or a simple asp.net web form just to make sure the classes are working properly.
Message 9 of 15
(3,879 Views)
7.1 is not compatible with .net 2.0.  Nothing to do about it if you can't convert other than use use .net 1.1 or use alternative e-mail means.  You can still use the e-mail vis that were part of the internet development toolkit.
Message 10 of 15
(3,878 Views)
