smoothing
Hi
Does anyone know if it is possible to get Labview to perform smoothing of
data curves? At the moment, I am importing data into a spreadsheet program
which can do Savitsky-Golay, FFT Filtering and adjacent averaging smoothing,
and it would be very convenient if I could do this from within Labview.
Anyone done this?
Jon.
(3,658 Views)
Hi
I'm not shure about what exacly you want to do, but if you use LabView 5.1
curve fitting you can do with de
FunctionsPalette/Mathematics/curev fitting
and FFT goes with
Functions Palette/Signal Prosessing/Frequency domain
in this two libraies you can find several VI's
If you do not see this on your functions palet change it within the menue to
Edit / Select palette set / default
Cheers Tobias
"Dr Jon Atkinson" schrieb im Newsbeitrag
news:905kr6$nb6$1@usenet.bham.ac.uk...
> Hi
smoothing,
> Anyone done this?
> Jon.
(3,657 Views)
Hey
I have downloaded two vi´s with S-G smoothing from I don´t know where.
If you are interested I will send you these files
"Dr Jon Atkinson" wrote:
>Hi>>Does anyone know if it is possible to get Labview to perform smoothing
of>data curves? At the moment, I am importing data into a spreadsheet program>which
can do Savitsky-Golay, FFT Filtering and adjacent averaging smoothing,>and
it would be very convenient if I could do this from within Labview.>>Anyone
done this?>>Jon.>>
(3,657 Views)
