smoothing a digital input
I have a digital input coming from a third party device, LawsonLabs Model 301.  It is an analog to digital converter converting a voltage and sending me a number.
This voltage is not as steady as I would like it to be so I've looked around to find a vi that does some kind of averaging.  I know that I can easily achieve this myself by taking some samples and averaging them.  I wondered if NI would have a vi that does this, though.
Thanks for any help in advance.
Ron Deavers, CLD
(3,191 Views)
Look for the decimation vi in the examples.
(3,182 Views)
How about the Mean function?
(3,179 Views)
Depending on your signal noise maybe also the median filter is worth mentioning.
Search the examples for  Median Filtering.vi
Greetings from Germany
Henrik
LV since v3.1
(3,166 Views)
I'd suggest to use the vi "Mean ptbypt". There you can define the number of samples to be averaged.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,161 Views)
