smooth a point-by-point sinus
Hello everybody,
I have a problem of sampling. I use labview 8.5 and a compactrio. In my application, I have to give a low frequency sinus point by point at the output of the module NI 9263. The output must control an loudspeaker. But in the compactrio target, I have a loop that run at 2ms, so I transmit a point every 2 ms on the fpga and then at the output. The problem is that my output sinus is not enough precisely sampled. So when I try to send my signal to the loudspeaker, I have a high frequency du to the steps of the sampled sinus. So, how can I smooth my sinus at the ouptut for not hearing any more this unwanted high frequency?
I thought of a lowpass filter on the fpga, but is it possible?
Thanks for your answer
(2,670 Views)
The problem is that at the output of the module NI 9263, your sinus doesn't look like to a sinus any more, but it's more a quantified signal. The best you can do is to oversample your signal by 2, by adding a point in middle of 2 points, more exactely by interpolating your signal.
You could do that either by adding a shift register in your while loop, or you can directly use a VI function "linear interpolation" in FPGA Math & Analysis -> Utilities
This should eliminate the high frequency and as a consequence the noise in your loudspeaker.
Best Regards,
Laurent
NI Switzerland
(2,618 Views)
