smith predictor
Ive been working on process with large time delay, so i need to implement smith preedictor of actual process. I have tested smith predictor in simulation but in actual process i am finding it difficult to make inner loop.
Thank You
(3,097 Views)
Thank You
Attach your VIs (not pictures, but the VIs, themselves).  If there are multiple VIs, put them in a folder, compress the folder, and attach the resulting .zip file.  Include data if necessary, and try to explain where and why you are "stuck".
If you want someone to program this for you, there is a Forum where you can look for Developers for Hire.
(3,063 Views)
