smartest way to create Help for application
Hi all,
I'm looking to design the coolest and smartest way to add help functionnality to an application.
What I would like : the user push on F1, and click on any control//indicator on my application and this open a web page depending on where he clicked.
=> The problem is that it requires an event "application: mouse down", which doesn't exists.
Coding events for each control//indicator would be too long, and not clean in my code !
Any idea ?
P.S : It could be a great idea to forbid the word "help" in message object such as "I need Help" or "Help to do..."
V-F
Message 1 of 11
(3,353 Views)
@ramses64 wrote:
.....The problem is that it requires an event "application: mouse down", which doesn't exists....
The Mouse Down Event does exist! For almost all Frontpanel Elements.
Christian
Message 2 of 11
(3,345 Views)
You can make a combined event case for all your controls on Mouse Enter, which basically just remembers which control you're hovering over (e.g. store the control Label). When pressing F1, a helpfile about this Label is shown.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 11
(3,338 Views)
For an application with cluster of clusters of arrays of bools//int//datetime... etc, it's verry borring to create a mouse enter for each control//indicator.
And this solution is only for a vi, not for an application (with several user interface VIs)...
Christian : I don't search "mouse down event" for each element, i search "APPLICATION: mouse down"...
V-F
Message 4 of 11
(3,331 Views)
Applications don't receive mouse down events. Windows do. Thus, a MouseDown event would be tied to a GUI element, such as a control/indicator, or the window's pane.
Message 5 of 11
(3,316 Views)
So what could be the better way to implement a html help for my application ?
V-F
Message 6 of 11
(3,310 Views)
I never implied your method was bad. You said you were looking for the Application:MouseDown event and said it didn't exist, and I explained why. If you want to implement using your method I would suggest registering the MouseDown event for all your controls/indicators. You do not need to do this one-by-one, and you only need one event case. Look at the shipping example that deals with dynamically registering for events. That example shows how to register the mouse down event for all front panel controls/indicators.
Message 7 of 11
(3,306 Views)
You do know you can have 1 event for several items?
Attached is a simple and sloppy example, it'd be easy to complement with a AE to keep the label and also clear it on mouse leave event.
/Y
Qestit Systems
Message 8 of 11
(3,304 Views)
Hi smercurio,
I tried to register a dynamically event :
but this doesn't work : it only works for 1rst level controls (if a cluster is in a tab control, the cluster doesn't appears in references).
I should do a reccursive method to list all controls, but I think this wouldn't work : when you click on a cluster, this will give the reference of the cluster, and not of the control included in the cluster...
Thanks for your help !
V-F
Message 9 of 11
(3,303 Views)
Hi Yamaeda,
your exemple well works, BUT (there is always a but ! :-))
        - this is for a VI (I have to implement this in all my user interfaces)
        - this is for simple controls, not for clusters of clusters of arrays of clusters...etc...
        - for a large application, I will have to list items one by one on the event structure...
Best Regards,
V-F
Message 10 of 11
(3,298 Views)
