small size runtime?
Is there a small size run-time for lv?
would like to distribute exe via email to end users. my programs are small in size, but with the runtime they quickly become big!!!
thanks
(3,389 Views)
Hi Otman,
I don't know of a "small" run-time engine, but if your users have Internet connections (of reasonable speed), you could include a link to the NI website where they can download the runtime engine before using your EXE.  You could also mention in the e-mail that this step only needs to be performed once (if the users will be receiving multiple EXEs from you).  I think the link you'd want to provide is https://download.ni.com/support/labview/windows/runtime/8.0/LVRunTimeEng.exe .  There's actually two executables in that folder, I'm not sure what the difference between them is (other than their size).
Hope this helps,
-D
(3,380 Views)
@Darren wrote:
... There's actually two executables in that folder, I'm not sure what the difference between them is (other than their size).
The web portal to the LabVIEW 8.0 runtime engines has details on the difference between the two versions:
QUOTE: There are two downloads that are available. You only need to install one of them. LVRunTimeEng.exe is a smaller download intended when viewing Remote Front Panels in Web pages. It does not contain the full run-time engine, but will allow some executables to run. For full support for executables use the LabVIEW_8.0_Runtime_Engine.exe. This version will support all executables built with LabVIEW as well as allow viewing of Remote Front Panels in web browsers
(3,373 Views)
thanks everyone that responded! you're help was greatly apprecaited.
I knew that theren't wasn't a workaround to this problem but I thought I'd give it a shot asking anyway.
(3,340 Views)
