slowing chart output
I am trying to slow the rate at which the data I am reading into my program is outputted to the chart. I would like the entire chart to take a few seconds. I have included the program, in LV5.1, that I am working with and the idea I had as to how to do this, but it does not seem to work.
Also, I am getting a line, from 0 to the last value, on the chart. I do not know where this line is coming from or how to get rid of it.
Please be specific with your help, as I am not very familiar with Labview.
Thank you!
(2,583 Views)
I've modified your vi. I think that it should work the way you want now. The reason you had those lines going back to 0,0 is because the Spreadsheet to Array function was adding a zeros to the end of the array. I didn't have time to figure out why so I just took a subset of the array minus the last element.
I hope it works, I got some warnings when saving it for LV 5.
See if this is what you wanted...
oops... forgot to change your file path back, so you'll have to do that...
Brian
(2,583 Views)
