slider config
anyhow is it possible or not??
Message 11 of 13
(510 Views)
Hi jeet,
Yes.
Using property nodes you can manipulate the accepted input range and the steps between possible input values - as you can also set in the properties dialog of the slider…
Message 12 of 13
(506 Views)
yes but along with that the string and the multiplication value also should change. please  can you check the vi which i have attached ? that would be very helpful
thank you for replying
Message 13 of 13
(503 Views)
