single point in (0,0) using plot multy x-y
hi
I want to display two waveform(in  points )in  x-y coordinate(the x-y coordinate must be shown),
my method is  using  plot multy-xy.vi
1.initial a array(length:20   all number is 0)
2.using shift register and replace the index element of the array
3.using   plot multy x-y to dynamic display the array
but when the plot multy-xy was used,  the (0,0) is always the first point.
the detail is in the attached file
(2,660 Views)
your problem lies in the small points drawn on the screen
I changed your program so that I could read it and added a Quotient and remainder function so that after 20 points the loop would continue.
Just wait for 20 points and see what happens after that
greetings from the Netherlands
(2,633 Views)
