single pin interface
hello,
I have a component with a single pin interface. I do send a word of 20 bits and one start bit and one idle bit.
How do I program the device? (module, serial output ...)
thank you.
manu
(3,796 Views)
Thanks for posting on NI forum.
With LabVIEW you can create an array that correspond to your frame.You can also send your frame bit per bit.
Nicolas M.
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter avec LabVIEW - Développer avec LabVIEW
(3,771 Views)
hello,
thank you for your indication, but how do I send the frame with which module because I have a frequency to respect.
thank
manu
(3,754 Views)
Hi manu23
How do you have to send it?
is it you have to send the data using a digital line?
Prashant
(3,747 Views)
i have a OPT register.
(3,738 Views)
If you want to generate a digital "frame", this NI modules have digital outputs :
NI 9477 ; NI 9474 ; NI 9476 ; NI 9472 (users manual are aviable on this links)
I give you this link too. It's an example of sending header frame.
Nicolas M.
(3,706 Views)
