sine square function in formula node
Hello
I need to generate a function
I = Iz * sin^2(B)
where B = (pi/2)*(V/70)
Iz = 0, 0.1, 0.2, 0.3 ... 1.0
V = 1,2,3 ,4...135
I tried to do thi sin formula node. but cud not get it.
See attchment.
Nghtcwrlr
(7,747 Views)
This will not work. B has 105 elements, and IZ has only 10. B and IZ must have the same numers of elements. And you should perhaps use a for loop not a formula node
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(7,731 Views)
Ok.. i somehow managed to get it,. thankss
Nghtcwrlr
(7,712 Views)
Hey can you attach a vi that successfully implements the sine function in a formula node?  I need to make:
12 + 150sin(B(X-22000)) where B =  (Pi/7200).  Please help me out with this, and it has to be in a formula node to fit into my project.
Thanks for any help.
(7,642 Views)
Why does it have to be in a formula node?
Is this homework?
(7,638 Views)
Kind of - a class project.  Is there way to put a simple sine function inside of a formula node or not?  If not I need to do some major rewriting.
(7,623 Views)
Hi SMLion20,
The code below may help you:
(7,614 Views)
