simultaneous generation of two frequencies using pci 6036E. and LabVIEW
Dear Sir
We are using currently DAQ 6036E card for generating the frequencies using LabVIEW. We need two analog sine waves simultaneously with identical frequencies, amplitude and phase.  Is it possible for us to write LabVIEW software using this card for simultaneously obtain two frequencies from two outputs. We request NI to provide us technical support in this regard.  Our application is two channel frequency generation simultaeously using this card for exciting the two piezo driven transcedures simultaneously at same frequency, amplitude and we want to vary the phase between the two through LabVIEW SOFTWARE.
Kindly help us in this regard
Mohan
(2,783 Views)
Hi Mohan,
Let's continue this discussion in your other forum, here.
David L.
Systems Engineering
(2,760 Views)
Dear Sir
I am not able to see any support response. Kindly let me know further.
regards
Mohan
(2,753 Views)
I am Fahad from Oman
Brother Mohannad,
I've got some enquiries with Labview and I need ur Help,
could we contact using hotmail, realname_88@hotmail.com
it would be nice to know u brother
(2,747 Views)
Hi Faha,
If you have National Instruments Standard Service Program (SSP), you may contact us via email at ni.com/support. If not, than we can continue conversations through the discussion forums. Also, let’s continue this issue on the original forum post here. This will help us and the community to all follow along in the same place.
Message Edited by David L. on 06-19-2007 05:49 PM
David L.
Systems Engineering
(2,720 Views)
