simulation of three phase induction motor using LabVIEW
I want to simulate a three phase induction motor using LabVIEW 2014. I have all the required equations. Is there any library or toolkit I can download for simulation of induction motor in LabVIEW?
Message 1 of 14
(8,705 Views)
Please help me out
Message 2 of 14
(8,660 Views)
Well, if you have all the equations, you know the needed inputs and resulting outputs.
What exactly is giving you problems?
(Of course LabVIEW is a programming language, not a circuit simulation such as discussed in the "Circuit Design Suite" forum.
I assume you are familiar with LabVIEW programming and understand the capabilities.)
Message 3 of 14
(8,650 Views)
I'm pretty much new at labview but I know how to implement those equations. But there are some parameters which are considered to be constants. So, is there any library made for electrical machines where we can just give inputs and parameter values to generate the output simulation?
Message 4 of 14
(8,642 Views)
Maybe you also want to explain what you mean by "Simulating ..."
Message 5 of 14
(8,623 Views)
I suggest you look at getting a tiny bit more familiar with what LabVIEW is and what it is not.  In the upper right corner of the Forum are a number of links to on-line tutorials and training -- spend a little time getting more familiar with LabVIEW, see if you can write some code that will do what you are thinking about, and come back with more specific questions.
As far as I know (and I am not an "electrical machines" expert), there is no canned set of VIs or library in LabVIEW that you can plug in some parameters and it will do all the work for you.  Could you write such a thing in LabVIEW?  Sure.  Could you write such a thing in LabVIEW?  Not without becoming more experienced with LabVIEW.
Message 6 of 14
(8,586 Views)
I think you are missing the Electric Motor Simulation Toolkit on your machine:
https://www.ni.com/en/support/downloads/software-products/download.labview-electric-motor-simulation...
Here is the function:
https://www.ni.com/docs/en-US/bundle/labview-electric-motor-simulation-toolkit-api-ref/page/lvemsimv...
Barp - Control, Simulation, RTT and HIL - National Instruments
Message 7 of 14
(8,551 Views)
Do a search for "LabVIEW motor simulation":
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=labview%20motor%20simul...
Although you won't find much of anything on the cheap that will compete with NI's own Control and Simulation toolkits you will find a lot of people have already been down this path and you may be able to leverage some of their work.  Of course if you have the money to afford the NI toolkits they will make your life easier.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 8 of 14
(8,524 Views)
I'm trying to use equations and parameter values for simulation. It's complicated but I think it will work. Thanks for all your replies.
Message 9 of 14
(8,517 Views)
Infact I am also working on same project.You may contact me at my email add. : sksinghnitn@gmail.com
Message 10 of 14
(8,163 Views)
