simulating pxi system
Can a PXI system be simulated for testing? If yes how?
Thanks for the help!
(4,869 Views)
Hi C.DOT,
do you mean a complete system or only some cards? What do you mean with simulated? Do you only need the PXI card to test some DAQmx functions or do you want to read counter values or such things?
Mike
(4,867 Views)
You cannot simulate an entire PXI system. You can simulate certain cards. Consider: how would you simulate the PXI controller, which is basically an embedded PC?
(4,847 Views)
sir,
But where can i find the list of certain cards which i want to simulate.
thanks for you are previous answer .
Best regards
Tanzeel
(4,832 Views)
Hi Tanzeel,
Hope it helps.
Mike
(4,809 Views)
If you start Measurement and Automation Explorer and look in the left hand pane, you'll see Devices and Interfaces.  Click on that.
Then in the right pane, at the top you'll see Create New.  Click on that and select NI-DAQmx Simulated Device.  This will take you to a menu where you can select the specific device you want to simulate.
Not all devices can be simulated.  But quite a few can be.  My laptop currently has a few PXI cards as well as some SCXI ones simulated.
Patrick Allen: FunctionalityUnlimited.ca
(4,805 Views)
